AFR low 11 stock s2k?
My S2K has test pipe + amuse + headers + aem intake..
I try to see the AFR with a wideband inovate... low 11!!! :/ :/
I have connected stock lamda but without any spacer. So the check engine is ON.
Stock ecu is going on safe mode without cat? So it try to make it rich?
When are you experiencing the low 11's AFR? At idle/cruise? Or under full throttle?
If its under full throttle then that doesn't sound wrong. If that's at idle/cruise then yeah that sounds too rich.
When I was running on the stock ECU I would see 11's frequently under WOT on my AEM wideband. At the time I had an intake, PLM header, test pipe, OEM exhaust.
Not sure if that's out of the ordinary, but its what I saw with that setup.
