AEM version 1 intake install help
dookie , probably not through the headlight gap. I wouldn't worry, but the if you install the AEM V1, you need to cover the holes as water pours directly into the filter otherwise.
thanks guys.. do u guys have any methods of cleaning the whole intake? i need to clean it before i install it thats why. the intake just came with metal piping, i use my stock hoses right, and its missing a clamp. in the picture one of the holes is right where the fender cuts off and the other is straight up by the sticker?
You are right about the hole locations.....you'll see them when you pop the hood.
As far as factory hoses....you will be relocating the factory Air Control Solenoid Valve and will need 1/8" vacuum lines to extend to the mounting location.
You'll also need a 5/16" hose that goes from the bleeder outlet to the throttle body.
Seriously, I can fax the AEM instructions to you. It describes all the parts you need to complete the install.
The extra hoses and clamps should only cost a few bucks.
As far as cleaning.....I'd probably pull a clean towel through the pipe....it really shouldn't be dirty to begin with.
Did you get a filter with it? If you need a replacement try a K&N RR-3001.
Good Luck!
Good Luck!
Originally Posted by Cubs2k,Aug 4 2004, 01:32 PM
i check those holes with a flashlight and i don't see how water can channel through those holes and pour directly onto the filter...
but im still gonna get something from the hardware store to cover it...
BLOP,
In the picture, it is the the two black plugs, each located below a fender mounting bolt, just inside the the edge of the fender. Darn, wish I had PhotoShop.
When your car is in the rain with the V1 installed, the water channels down and into those two holes.
Dookie, when I looked down through the holes I'm talking about, I can see my filter.
K i see them... Why is it that no one ever gets the name right, even for the past 3 years of online RPG everyone called it BLOP, its B-O-L-P no offense, just never made sence to me
