AEM V2 & CEL Light
AEM V2 & CEL Light
I just installed my AEM V2 and after about a day of driving the check engine light came on. I didnt reset my ECU after install so this may have been the cause of the problem. But in any case could some walk me through the process of resetting it or tell me another way to get the light off
Pull fuse #25 (7.5A at 3rd position from the top on the right) for 30 seconds with the key out. Although, that probably won't fix it. It sounds to me like you crossed some vacuum hoses.
Note: the 1st position at the top right is usually empty.
Follow this thread:
https://www.s2ki.com/forums/index.php?showtopic=105368
Trace the lines step by step and note the white check valve orientation.
