AEM UEGO
AEM UEGO
Just curious to see where some of you guys routed the harness from the O2 sensor to the back of the gauge. I have a gauge type w/ controller built in and it is going in a SOS a pillar pod. Seems like I have plenty of cable but I almost never found a place to run my laser shifter wires through the firewall. Is there any access under the car?
Thanks in advance.
alex
Thanks in advance.
alex
Not exactly how I want to do mine but a possible rout:
https://www.s2ki.com/forums/index.ph...&f=71&t=267255
I was thinking maybe where the wires cross through by the battery. The only problem is I can't find where they actually enter the cabin nor can I figure a way to go through the dash...
Here is a good write up on the uego,
https://www.s2ki.com/forums/index.php?showtopic=175549
If you have the Gauge type the orange wire reffered to in this post is actually the White wire on the Gauge type to pin C16. The monster clip for the sensor can be removed (it was grey in color on my connector and the actual connector was black), Remove the gray clip to make the connector smaller then I dremmeled out an existing hole in the fire wall just big enough for the plug then put the grey clip back on! Here is where I put my Gauge - Next to the start button.
