AEM EMS Cold Start
AEM EMS Cold Start
I have a hell of a time starting the car in cold weather or when I let it sit for awhile. I am guessing it has to do with the start. Has anyone figured out the best way to get around this with the EMS?
The last sentence of this post by UL may be of interest to you:
https://www.s2ki.com/forums/index.php?showt...dpost&p=5103822
I've been playing with the initial pulse value and the extra fuel tables (based on coolant temp). Right now, my values are roughly double AEM values below 35-45 degrees. It seems to have greatly helped.
tim
tim
Lots more fuel for the fuel pulse and lots more enrichment for cold coolant temperatures otherwise it will start and then die. It is also common to have a battery drain problem too. With an ammeter check the current drain from the battery with everything switched off. There are a few other tricks too but I would have to be at your car to try those.
Originally Posted by gilbertg' date='Feb 16 2005, 10:11 AM
"Lots more fuel for the fuel pulse and lots more enrichment..."
Thanks,
Dave
Originally Posted by bgbfflochp' date='Feb 16 2005, 12:25 PM
When I have my problems, the car just doesn't start and appears to have a dead battery. When the car does start (90% of the time), I have to let it idle for about 3 minutes.
If I don't ride the clutch, the car will choke and shutoff, then I can't start it for 2 hours or so...and it requires a jump start.
pm me with your e-mail address. I'll send you a copy of my map. It will be easy to see the changes I have made to the startup tables with the compare feature. The initial crank pulse has been greatly increased as has the extra fuel the coolant enrichment table adds. I think I also extended the initial start extra time. I can easily start in temperatures down into the 15-20 degree range now. Sometimes the battery injector offset values are off if you're running aftermarket injectors. I believe those will also dramatically affect cold start. Good luck.
Tim
Tim
