AEM ECU-OE Secondary Air Injection removal?
Old 02-14-2009 | 09:37 AM
Resident Sicko's Avatar
Default AEM ECU-OE Secondary Air Injection removal?
I bought a "block off plate" to remove the Air Control Valve and realized just how much equipment the Secondary Air Injection system includes...
In the interest of cleaning up the engine bay, just how much of this is needed? The car will never be CARB certified and is running a vortech blower, Comptech exhaust etc...
Can all these items be removed without needing another tuning session?
1. Air Control Valve
2. Air Control Valve Vacuum Control Solenoid Valve
3. Air Pump Relay
4. Air Pump
5. All hoses, vaccum lines, etc. that are connected to the above units.
Lastly, in the event there may be "open ends"...is a "cap off" recommended?
Thanks in advance.
Old 02-14-2009 | 09:59 AM
RAIN H8R's Avatar
You can remove all of that with no issues. the whole secondary system has NOTHING to do with a tune. I myself am doing this right now.
Old 02-14-2009 | 12:20 PM
Do you plan on capping all extra open ends? Are you running a supercharger or turbo?
Old 02-15-2009 | 10:03 AM
This is pretty involved...what are the dis-advantages of removing everything? We have a LOT that the secondary air pump is connected to!
Old 02-15-2009 | 11:24 AM
RAIN H8R's Avatar
I am running a COMPTECH SC setup. All you will need is a EGR Blockoff plate (I am making my own and will have a few extras made to sell)
Old 02-15-2009 | 05:11 PM
ChefJ's Avatar
The machined block off plate from IP is quite a nice piece and very inexpensive. Besides that you can remove alot of the hoses in the evap system aswell.
Old 02-15-2009 | 05:31 PM
Thanks, guys..I wanted to do this while the car is up on jackstands for other work (suspesion, oil pan powdercoat and blower check-up at Vortech), but get nervous when I start disconnecting things when I cant hear or see a difference when each hose is pulled...trying to limit the amount of variables just in case something doesnt fire when back together.
Old 02-18-2009 | 01:19 PM
Everything is out. WOW. Quite a lot of stuff once vacuume lines under fuel rail, vacuume canister on cross beam and air pump/hoses...
Not sure if there will be any issues with the open circuit lugs from air pump but will see once eveything is back together.
Will weight it all to share for you hard core autoXrs..
Old 02-18-2009 | 07:48 PM
RAIN H8R's Avatar
nice. I just wrapped my clips up with electricall take and zip tied them to secure locations..
Old 02-18-2009 | 08:00 PM
camuman's Avatar
ur aem ems right? if so, aem could care less about that stuff missing. my air pump thingamabober and misc crap assoc with it is sitting in a closet, WHERE IT BELONGS.
