aem cai cel light
aem cai cel light
Ok well I installed the AEM intake a couple days ago and everything worked great, parked it that night, no problems
I started the car the next morning and the cell light came on right away. Still runs normal, goes into vtec and what not, just not sure why the light came on.
Does anyone have any suggestions? I did not disconnect the battery when i installed the intake, do i need to reset the ECU? Thanks for any help you can give me
You do not have to reset the ECU when you put a mod on. It'll learn on its own in due time. But now that you have one, you might want to pull the code first to see what it really is.
I'm thinking you messed up the vacuum lines when you did the CAI and the CEL will read P0411. Follow the steps and pictures here and trace everything.
https://www.s2ki.com/forums/index.php?showtopic=105368
Originally Posted by outcrnru,Jul 20 2006, 06:08 PM
cool, i routed evrything the right way except the check valve isnt in place, would this cause the problem?
thanks
thanks
ItalianBucwheat
07-14-2002 03:40 PM
