AEBS Head Studs
About six weeks ago I installed my Alaniz worked head with AEBS studs. I'm now in the process of pulling the engine for a sleeved block and was wondering if anyone has experience with head studs. Should I/can I re-use the studs or should I spring fpr a new set? The folks at AEBS say they are OK to re-use. What do you think?
You actually want them to be stretched, that way they'll torque down. But I'm pretty sure AEBS head studs come pre-stretched. There's nothing wrong with reusing head studs, though the reason we use them is to save the head from wear/tear; removing/replacing head studs negates that, but since you're switching engines, why not.
I would chase the threads and clean them up, both in the head and on the head bolt before you reuse them. Also, you don't need to use a 10ft breaker to tighten head bolts. Just run them down by hand (if they don't go in by hand, they're not clean) til the end of the threads, then give them a 1/4 turn past that.
I'd go by the recommendation in the Helm's manual. I know it's talking about OEM head bolts, but it should be the same. I think it says something like "It's OK to use them, but if you hear squeaking as you tighten them, then you should toss them." I don't have it here by me, so I can't quote it verbatim, but you might check it out. I know there was a reference to re-using head bolts.
hey fperra what where your final results with the stock block and alaniz head, did you go up to 12-14 psi, if so did you get any dyno time? Anxious to know only becuase I am still waiting for my car to get done. thanks in advance
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Originally Posted by alexf20c,Sep 9 2004, 06:36 PM
Head bolts are NOT the same as head studs.
But I'm glad you pointed it out. I don't expect many people will have experience w/ replacing their head studs, but hopefully someone will have some relevant knowledge (other than what you've already posted).
Originally Posted by 03S2KAY,Sep 9 2004, 06:35 AM
hey fperra what where your final results with the stock block and alaniz head, did you go up to 12-14 psi, if so did you get any dyno time? Anxious to know only becuase I am still waiting for my car to get done. thanks in advance ![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
