Advice on Reactivation of Air Bag System
Needing advice
I just replaced my driversde and passenger air bags, seat belts and SRS controller. I have hooked up all the concections except to the SRS control unit. Is there a specific proceedure to do this or can I plug it in and go? can someone advise??
Thanks
Thanks
Disconnect the battery for 3 minutes to allow capacitors, etc. to discharge, then hook stuff back up, hook the battery back up, do the idle learn, then you're good to go. (assuming, as Slows2k said, the SRS light comes on for 5 seconds, then goes out when the key is turned on!)
No jumper is needed, neither are any Honda specific scan tools. You disconnect the battery, replace the components that deployed and the SRS unit. Hook up the battery and key it up. SRS light goes out, sytem is normal. Clearing a SRS DTC, and troubleshoting a DTC are different processes.
That's all you'll need for component replacement after deployment.
dillonkennedy003
12-17-2018 04:38 AM
