advice on fluids
advice on fluids
so im getting s2000 tomorrow and im going to change all fluids ive got....
engine /mobil 1 10W30
transmission /?????
rear diff/mobil 1 75W90
so can any one tell me what is the best transmission fluid ive seen.. gm synchromesh /honda mtf / redline / pennzoil synchromesh
so can sumone please tell me what is best and if so where to buy it and i know use 5.1quarts for the engine but not sure about transmission and diff can any one tell me the amounts needed
here she is i cant wait!
transmission /?????
The car looks nice. You can check this thread for the DIY info on fluid changes.
https://www.s2ki.com/forums/index.php?showtopic=548714
I used the Honda MTF from the dealer and just made the car level and filled until the fluid just barley started dripping out the fill hole.
Same procedure using mobil 1 75w90 in the DIFF.
either redline fluids all the way or honda syncromesh tranny fluid for your transmission and OEM diff. fluid also... I have had diff problems in the past (former owner never changed fluids since he bought it) and with the right fluid, EVERYTHING went away. I also had grinding sounds in the transmission from 1 to 2 also sometimes 3 to 4... ALL went away with new fluids
+1 on Amsoil. They make some of the best synthetic lubricants. I'm using there "Syncromesh" in my tranny and "75w 90 Severe Gear" in my diff. Used Redline before in my TSX and my Civic Si's trannys and hated it. Night and day difference when I changed to Amsoil Syncromesh.
Strife350z
01-25-2005 04:48 PM
