Added a J's Racing Oil Catch Tank...
Home Depot's clear braided line doesn't collapse, and it looks like the blingy JDM sourced line.
Edit: just saw that you where in the UK, Not usre if they have Home Depot there
Look for hose rated for low pressure (carbureted) fuel line and PCV use.
Thanks for the input guys, HomeDepot is a bit for me, seeing as I live in the UK! Will take the PCV with me, to make sure I get the right hose diameter!
j_c_a, where did you get those fantastic battery connectors?!
Originally Posted by j_c_a,May 26 2006, 02:04 PM
Either way Granteds2k has an idea of what to do.
Mine did the same thing(good year ASE grade vaccum line), it would get hot and start making a WHOOOP WHOOOOP noise like some hardcore raider fan.
I reuse the OEM reinforced tube, extending so the heat will not be a problem, since i do not care how it looks, i am happy with it.
*before the addition of the oem tube
Home Depot Catch can(2/5 full since last oil change)
Originally Posted by j_c_a,May 26 2006, 08:04 AM
For AN hose i think it's -6. IF you want braided, Summit Racing ships really fast and it looks soooooo much better.
I want some,I need some,,,please...Tell me where.!!!
For those who have questions how much coolant would you put in the reservoir what I did was talked to Yasu of J’s Racing USA based in Southern Ca and he wasn’t sure how much but I thought, I’d top off my old coolant resevoir up to the “MAX Line” then pour it in the J’s racing reservoir. Problem solved
hope this helps
hope this helps
hope this helps
hope this helps
