ACT Clutch/flywheel Chatter
So here's the story.
I just had my clutch/flywheel installed today, and now there's this mechanical gear noise that is fairly loud whenever I'm in gear with no throttle input.
Even if I am engine braking, if there is the SLIGHTEST throttle input, even small enough that I'm still slowing down, the noise is not there.
The noise is most noticeable between about 2-3k rpms, and almost disappears if I am under 2k rpm.
The noise is only present when the clutch is FULLY engaged.
Is this normal? I wasn't expecting a huge amount of chatter... the engine is still silky smooth, and there is no noise at all if the clutch is fully disengaged...
this is exactly what I experience with my SPEC clutch. does the ACT you used have 4 or 6 hub springs on the clutch disc?
apparently, discs with 6 springs will make that kind of noise on our cars. it's nothing to worry about as far as failure, but it's irritating as hell
ive had 2 different act clutch kits and they were both fine I had the hd pressure plate with the 6 puck disc then another hd pressure plate and street disc.
if its not alligned right it can "chatter"
Originally Posted by psychoazn,Jun 17 2008, 06:11 PM
I was under the impression that the ACT SS friction disk has more torque capacity than the OEM?
Plus, they're sold together
