ACG fuse
ACG fuse
Alright I know this topic has been touched on before. I did a little research and followed everything I was able to do. The ACG fuse, fuse #6 under the dash keeps blowing after about a minute while the car is running. The fuse is causing the CEL to come and throw a number of codes. I checked the electrical connections; what I could see but couldn't find any bare wires or anything. I had the alternator checked found out it was bad and replaced it with a new one but the fuse kept blowing. At this point i'm out of options of what i can do myself. Is there anything else to check for or should I just take it to Honda. Any input will be helpful.
Ok. I looked at it a few days ago but didn't see any wires pulled away. I have those wires tied back from the drive belts but imma double check it again in the daylight to be sure.
for what its worth, i had this same problem on my 95 si this week. i kept blowing the ACG fuse over and over again. i replaced the main relay and the ACG fuse and it started up just fine last night.
2x6spds
08-21-2001 11:18 AM
