Accidental gear grind....
Old 10-14-2013, 04:00 PM
BuellRunner's Avatar
Default Accidental gear grind....
Hey all,
Im a newbie to the s2k world, I just got my first - a year 2000 s2k with 160km. Bone stock, needs a little TLC but all orginial - from the original owner....Anyway, long story short - a friend took my car for a spin and accidentally caused a quick grind into 3rd on a quick shift at high rpm from second....Im assuming that I heard the synchros grind....
Been about a week and all seems fine. Can a single grind cause damage? Anything I should look or feel for?
Thanks in advance for any help....
Old 10-14-2013, 04:06 PM
starchland's Avatar
Your fine.
Mis shifting, on the other hand will make you cry like a baby. Utilize proper shifter grip technique
Old 10-14-2013, 05:48 PM
I think it was a misshift...
I don't think his hand and feet were working together very well....
Can these synchros handle a few misshifts/grinds and keep going?
Sent from my iPhone using Tapatalk - now Free
Old 10-14-2013, 05:59 PM
dwight's Avatar
Mis-shifts and gear grinding are usually very different.
Mis-shifts are when the wrong gear is selected. This is a problem caused by the right hand. This results in the engine running at an unintended gear ratio. An example of this in trying to shift from 6th to 5th, and accidentally going to 3rd. This can force the engine past its redline causing valvetrain damage.
Gear grinding is usually from the clutch not being fully disengaged while shifting. This is a hand/foot coordination problem. This causes the clutch to re-engage before the gear is fully selected and the dog teeth rubbing.
http://auto.howstuffworks.com/transmission3.htm
Old 10-14-2013, 06:03 PM
Thanks for the clarification Dwight. I was wrong it was not a miss shift. It was simply a grind.
As my car is new to me, I'm still in honey moon mode with it The more I read and learn however the more I am discovering that these cars can take an absolutely amazing amount of abuse and still continue working unbelievably well.
Old 10-15-2013, 10:03 AM
realblag's Avatar
The lesson you need to take away from this experience is: Do not let a friend take you car for "a spin".
Old 10-15-2013, 10:13 AM
Agreed. If by some chance I do have to replace my synchros at some point in the future what type of a cost am I looking at?
Old 10-15-2013, 01:23 PM
dwight's Avatar
You're fine. Don't worry about it.
Old 10-15-2013, 02:28 PM
Cheers
Old 10-15-2013, 02:41 PM
MBHs2k's Avatar
We have all grinded gears a few times over the years. It just happens. Don't worry about it
Quick Reply: Accidental gear grind....
