AC Issue
AC Issue
My A/C went out, after I ignored the signs that it was about to happen, and now I cannot get the mg clutch for the compressor to spin. While I was tooling around with the relays I blew fuse 21 in the interior panel (Heater control/Cooling fan relay). Now the radiator fans wont spin, they were spinning before with the A/C switch on. I replaced the fuse with the same rated fuse from the power mirrors, still not working.. I have checked the relays to make sure they are getting voltage and pulled all 3 related to A/C and cooling fans to confirm that they have continuity, they do. The only thing I can think to do about the A/C is to check the connector at the compressor for voltage, I have not had time to get under the car yet. I am completely lost on why the fans worked and now the do not. I have checked every fuse I have seen between the three boxes.
Any advice is much appreciated, I have been reading old posts on the forum and messing with this for most of the day now.
I have not. Update though, I took it for a drive tonight and the fans perform their primary function (turning on to cool the radiator), however they do not turn on with the A/C switch. I'm going to get under the car today and see if I'm getting power to the compressor or not.
I have seen one issue with the S2000 AC system, very simple.
The compressor clutch was slightly over shimmed. With the ac on, see of the compressor center clutch plate is spinning. If it's not, tap it with a screwdriver and see if it engages. If it does, re-shim to .005 thinner and you're done.
