ABS Sensors
ABS Sensors
I was doing some research but I couldnt find answer to whether or not.ABS sensor are interchangeable, I need a LF and I found a LR, will it work if I use a LF on LR on a MY01?? Thanks in advance.
All four sensors are different. They aren't interchangeable. The sensors themselves are likely the same but the configuration of the wire and mounting locations is somehow different.
Plugs are different front to rear.
Mounting is different side to side but will work. The mounting holes for the wire harness will not line up so its kind of a hack.
mroverkill
09-16-2015 06:08 PM
