ABS Removal. Want to rid of the whole module.
theoretically they should work just like stock (minus the abs) and the rears will have less pressure going to them due to the prop valve. i know summit has a four wheel prop valve that you can adjust the front and rears with. that may be an option.
PeanutButter,
You might want to run twin master cylinders for front/rear and a manual cockpit accessible proportioning valve to adjust the bias. Easier said than done. Also, use as much hardline as you can. Get them re-formed if this is accessible to you.
-Asura
-Asura
I did Laguna Seca with no ABS Oct 2nd. I only locked up on two corners. ABS is a nice safety feature, but not a requirement especially on a race car.
