ABS Removal !
ABS Removal !
hi
I have a right hand drive S, and I am going FI. But I have to remove the ABS Brake Modular/ box, what ever it is called, because of the turbo.
Has any one done this? Or have any advice!
Thanks
sacha
You might contact an s2ki sponsor called Mase Engineering. They are making a turbo kit for RHD cars that will not require you to remove the ABS.
https://www.s2ki.com/forums/index.php?showtopic=613561
You should probably post in the FI forum to see if there is anyone in the RHD world who has installed a Lovefab. They might be able to give some insight.
Sorry I don't have any advice, but I'm curious why you need to remove the ABS? Is it just a physical space issue or something else (that I am having a hard time imagining)?
Originally Posted by AusS2000,Sep 4 2008, 06:31 PM
I have a Lovefab V1 Minime and RHD.
All I did was move the abs unit a bit closer to the fender.
I did this by modifying the supporting bracket.
