ABS Pump replacement
Hi Guys
i bought a 2009 S2000 recently which had the vsa light on
i took it for diagnosis
and it had code 66-1 brake pressure sensor failure
after speaking to the electrician he said that these a fault with abs pump and either i need a matching abs pump or i need to get my abs pump rebuilt
the first query i have is do i have to get a abs pump with matching serial number (my pump is 57110-s2a-a514-m2, type:2avvv 06.2102-0262.4) or can i use one with a similar serial number abs pump
also if i remove this do i have to bleed the brakes or not
I think you just need to prime the accumulator by turning on and off the ignition key three times.
9KEVERYDAY
04-09-2019 09:20 AM
