ABS Problem
ABS Problem
Hi S2k Members,
My 1999 S2000 has its ABS light on, its on as soon as you turn they key and does not go out.
No blinking or anything,
I suspected that it was off side wheel speed sensor as the car was involved in an accident. The hub / upper wishbone and speed sensor was replaced.
The abs light is still on the brake fluid is around 6mm off the maximum level.
Any Ideas?
Charlie
Any Ideas?
Charlie
i did not know that made 99 s2000 but i just had the same problem and it was my fuse under the hood for some reson it wasn't even there, id check that if you havent already,
p.s. my car was also in a wreck
it really cant be much else sensors or abs unit, or the dash light itself, im sure there are threads about it on here check some other threads in the search section, thats how i solved my problem.
