ABS lights on
Old 05-12-2007, 11:45 PM
03supers2k's Avatar
Default ABS lights on
I finished installing springs and berk test pipe tonight took the car for a drive, and the ABS light is on unplugged bat; still on i have no clue?
Also i changed out my megans test pipe becasue it was always rattling because the resonator and installed the berks test pipe w/ my invida the exhaust now the car sounds raspy and wierd is this because the test pipe isnt on all the way tight or can it be a different issue somewhere else let me kno. This is going to be an allday project tomorrow
Old 05-13-2007, 12:36 AM
negcamber's Avatar
Check the sensors at each wheel...did you tighten them down? Check the wires from the sensors...it is very easy to damage or break them when changing shocks. Check the toothed ring on the hub that the sensor reads...a damaged tooth can throw the ABS ecu off.
Old 05-13-2007, 03:22 AM
CoralDoc's Avatar
Check these things and report back.
Old 05-13-2007, 05:01 AM
negcamber's Avatar
Whew...I spelled everything ok.
Old 05-13-2007, 05:53 AM
CoralDoc's Avatar
Are you shure?
Old 05-13-2007, 05:57 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
When doing FRONT suspension replacement, it is very important to unbolt the sensor wire where it bolts to the car (10mm). If not, when you pull the two front upper a-arm bolts to pull the arm back, you will very easily break this wire internally.
Old 05-13-2007, 08:48 AM
negcamber's Avatar
Originally Posted by CoralDoc,May 13 2007, 08:53 AM
Are you shure?
DARN YOU...made me look!
Old 05-13-2007, 08:54 AM
R3DS2K's Avatar
i think he is talking about your wheel speed sensor wires..
even tho the wire looks strong.. its just the housing or cover over the real wire inside it.. which is really thin and can break easily if it is stretched
Old 05-13-2007, 11:21 AM
03supers2k's Avatar
thanks guys i think thats the problem also i had a hard time getting the shock in place mayb i damaged it im gonna unscrew it and put it back together
do you have any suggestions about the test pipe
Old 05-17-2007, 07:06 PM
R3DS2K's Avatar
reset ecu
Quick Reply: ABS lights on
