ABS light NOT on
hello, I have a 1999 s2000, the ABS light does not come on at all when you first turn the ign on, the fault code in the ABS ECU shows battery power failure, the sensors are all working(shown in the live diagnostics)
I was wondering whether the ABS circuit works like some of the older charging circuits on cars, where if the charging bulb has blown, the circuit is not complete and will not charge?
could this be the same on the ABS circuit, just wondered if someone has removed the ABS light because of a fault, would this then break the ABS circuit, could this cause the 'battery power failure' fault to the ABS pump. Both the small and large ABS fuses under the bonnet are good and have live supplies,
any help would be gratefully appreciated
thanks, but the diagnostics show there is no power to the pump, and the ABS light sequence is needed for the mot here in the uk
If anyone knows about the electrical side of the ABS system, please let me know
thanks
thanks
Holeshot121
09-11-2021 12:17 PM
Silverstone2K
11-13-2013 10:31 PM
if lookz kill
11-30-2006 09:20 PM
