ABS light on - no power mirrors - no fan
Hello. ABS light came on few weeks ago. It was on temporarily in the beginning, but it is on most of time except when I drive constantly over 60mph.
MY is 2004 with 226,000 miles.
I know I should get it scanned first. When the ABS light is on & off, the power mirrors do not work (fuse is ok) and fan doesn’t work (fan light blinks).
Today, I tried cleaning the sensors & connectors without a success.
I pulled the wheels & cleaned the sensors. Also, I cleaned the orange connectors in the engine bay and inside of trunk lining.
What is the life expectancy of the wheel speed sensors?
Rear driver’s side sensor connector
I guess cleaning helped little as the ABS light is not lit most of time.
But, the abs light comes back on if I use Power mirror, heat temperature knob or AC. These must be related and using the same circuit.
Found the cause!!
I went to a local shop for ABS scan, but they couldn’t get any readings (they kept bringing bigger scanners).
The technician then looked a diagram for few min and said there is a relay affecting ABS/power mirror/ac under the dash. He showed me the location and suggested me to check.
I left the shop (no charge) & checked under the steering. There are 2 grey relays together. I pulled 2 & switched each other.
It fixed the original problem! This time, power acc port doesn’t work. Also, radio is acting weird.
The other relay must control the power outlet & radio.
I ordered 2 relays. Oem part: 39794-S10-003 (rc5102)
