ABS Light = Seized crankshaft?
Old 06-12-2005, 06:20 PM
Slows2k's Avatar
Originally Posted by billman250,Jun 12 2005, 09:11 PM
The ABS has DTC's just like the engine
Or are you asking what the code is.....I will know more in a few days.
I just want to know what code is stored
Old 06-12-2005, 06:25 PM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
From you bro, I figured it was the latter.... I will post it up when I get to it in a few days...
Old 06-12-2005, 06:59 PM
Banned
hondaS2001's Avatar
Originally Posted by billman250,Jun 12 2005, 06:14 PM
Not sure what you mean. I'm talking about play in the crank in relation to a seized piston. Healthy engines don't have seized crankshafts
I probably worded it wrong but I meant have you measured the play on the crankshaft of a healthy engine in relation to the play on this one? But, this one has ZERO play right?
Old 06-12-2005, 07:00 PM
Banned
hondaS2001's Avatar
also, does/did it turn over at all or while it was running for the short period of time did it make any funny noises?
Old 06-13-2005, 04:59 AM
Squeezer's Avatar
i'm thinking the ABS light coming on and the engine siezing are to unrelated problems that happened at the same time.
i know the ABS light will come on if you hold the brakes down for a long time, which he may have. the engine problem sounds like a spun bearing.
Old 06-13-2005, 06:23 AM
eviltwin's Avatar
any clutch or flywheel installation or work done recently.
Old 06-13-2005, 07:11 AM
Wisconsin S2k's Avatar
this was my thought as well. coincidence.
Old 06-13-2005, 07:45 AM
joes sled 2000's Avatar
Very interesting!!I've seen nothing like that at the dealership.I have seen altenators crap out and set off numerous false abs,srs lights though.As for the engine i would have to say that there was a lubrication issue.You might want to examine the oil filter,though rare i have seen a peice of the oil filter wrap inside the filter causing engine failure without Any warning(no oil warning lamp).Please keep us updated !!!!
Old 06-13-2005, 07:53 AM
Scot's Avatar
if the tires locked up at 90mph he more than likely didn't put the clutch in at the same time.... wouldn't that lockup the driveshaft...moving backward, wouldn't that stop the engine from spinning immediately?
not sure what RPM all this was done, but if you go from 5000rpm to 0 in absolutely no time something's gotta give. Most of the time you would have your foot on the clutch in a situation that you think you are going to lock up (obviously with ABS you don't "lock up").
make sense?
Old 06-13-2005, 08:45 AM
Billman250's Avatar
No clutch work done recently.
Oil filter is a PCX, I'm doubting it would fail but anything is possible.
Scot...I will ask him about locking the wheels and not disengaging the clutch.
Quick Reply: ABS Light = Seized crankshaft?
