ABS Light = Seized crankshaft?
Old 06-12-2005, 10:10 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Default ABS Light = Seized crankshaft?
Ok guys, here's another weird problem. I have an 00 s2k here at the shop, last 4 vin 33XX.
Here is what the customer has stated has happened. He is long out of warranty, a level headed guy, and has no reason to fabricate a story:
Quote "Drove up to 130+ mph (5th geer). Passing 125ish ABS light came on. Slowed down to 90ish, tested brakes; they locked up. Slowed down even more to 70ish, began hearing noise (I thought coming from rear) sort of like a thumping noise. Got off highway, drove .5 mile on local street, got on another highway, drove 60 mph. Noise persisted, car stalled 4 miles later while on highway. Coasted off highway, let car sit for 20 minutes. Tried starting car, had trouble turning over. Did start, engaged car in first gear, moved about 10 feet, car stalled, never to start again."
Upon initial inspection the crankshaft is locked up solid, verified by a 3 foot breaker bar on the crank. The oil is clean, done a few weeks ago, and right on the full mark. There are no leaks at all. NO CEL, or pending codes.
I pulled the plugs: no mechanical damage to plugs, all piston tops are equally carboned. I will post more findings as I go, only had a few minutes this weekend for a quick look.
I have done high speed runs of this nature countless times. Anyone care to take a stab on why this guys motor locked up solid? I can get 0 movement from the cranckshaft. You would think if a piston were frozen to the cylinder wall, I could get a trace of play in the crank. No dice.
Old 06-12-2005, 10:11 AM
Billman250's Avatar
One more thing....I will scan the ABS light and post it up.
Old 06-12-2005, 11:02 AM
Wisconsin S2k's Avatar
I'm willing to bet the ABS light is likely going to be a vehicle speed sensor malfunction.
As for why the crank is completely siezed i have no idea. Are there bearings or something that could be frozen preventing it from turning? I have never taken apart our bottom end all the way to the crank so I don't know. pardon if I sound like a newb. lol
Old 06-12-2005, 02:03 PM
Slows2k's Avatar
What ABS code?
Old 06-12-2005, 02:09 PM
Banned
hondaS2001's Avatar
Have you measured the play on the crankshaft on a perfectly healthy one? If so, what did it look like?
Old 06-12-2005, 02:35 PM
Defender's Avatar
could it have been the oil pressure light instead of the abs light ?
Old 06-12-2005, 03:26 PM
SIIK2NR's Avatar
subscribing
Old 06-12-2005, 04:43 PM
honda9krpm's Avatar
I've subsribed too.
Interesting and bizzare situation.
Just a quick stab at this would be oil pump failure but why
Old 06-12-2005, 06:11 PM
Billman250's Avatar
Originally Posted by Slows2k,Jun 12 2005, 06:03 PM
What ABS code?
The ABS has DTC's just like the engine
Or are you asking what the code is.....I will know more in a few days.
Old 06-12-2005, 06:14 PM
Billman250's Avatar
Not sure what you mean. I'm talking about play in the crank in relation to a seized piston. Healthy engines don't have seized crankshafts
Quick Reply: ABS Light = Seized crankshaft?
