ABS kicking on... Lightly braking 5-20mph
Aren't the ABS sensors all the same?
Just a difference in the brackets?
IOW, can't you try to move sensors around and ty-rap them to the upper arm (for testing!)?
As long as the wires are long enough, you could swap front to back I guess.
What if you put the car on jackstands, all wheels off the ground.
Start engine, in neutral and have someone else turn a wheel by hand to see if you can recreate the situation.
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
Originally Posted by ///MIKE' timestamp='1305300288' post='20571994
Btw, on a cold start this morning, sloping kind-of down hill... the abs was going nuts while I was completely stopped. I don't understand that at all...
I really want to pull my hand brake and run out to my passenger side sometimes... Tried to duplicate the other day... does it very rarely when the car is at a full stop. It is certainly changing braking distance for the worse.
Ok, changed sensor out. Took it for a spin... it's still there. Just as bad as ever. I am at a complete loss. I guess I'm going to have to take it into the dealer. I don't know what else I can do. Unfortunately, I don't have any money at the moment... so it's probably going to have to wait for awhile.
![cry.gif](https://www.s2ki.com/forums/images/smilies/cry.gif)
I had the same issues, but on a completely different car. The problem turned out to be a crack in the pulse-wheel. Perhaps you can check yours for defects?
I did disassemble all the brakes, re-lubed all the sliders, and re-assembled everything... no change.
It's just such an annoying problem.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
The dealer will probably remove and replace the main abs pump/controller for big bucks. They'll still have the problem so then they'll start to troubleshoot and find the real issue.
