? about oil filter install during an oil change?
Originally Posted by jesusphish,Aug 5 2008, 08:57 AM
I would like to know the history behind why there are so many variations for putting oil in an oil filter.
Then others are not comfortable with not filling it because of the pressure drop on initial start up.
I fill it half way.
If your working in a clean area, like a garage and use quality brand oils, you should be fine filling it up some.
Not filling the oil filter is usually a best practice taught companies that purchase oil in bulk that gets delivered in a lube truck and they keep it stored in old tanks for sometime. So by the time it gets put in, it is usually dirty if it has not been filtered.
I just poir a little oil onto the filter ans spread it around with my finger to lube the filter gasket. When I do that, a little bit of oil gets into the filter.
-Ian
-Ian
LostWaffle
03-15-2004 06:54 PM
