75W90 vs 75W140 transmission & diff oil
#21
You may recall that I have a diff temp gauge installed on my car. I can monitor the surface temp of the casing between two cooling fins all the time. I have seen temps get up to 90*C. This was during a road trip, immediately after a spirited pass of a slower vehicle. At steady state highway cruising, the diff typically runs around 70*C on a hot summer day. I also have cooling fin extensions made from sheet metal but I'm not sure how effective those are. Shortly after I posted pictures of my cooling fin extensions, Spoon marketed their new S2000 diff housing with elongated cooling fins.
#22
A bit of an offtopic here
SpitfireS: Regarding the engine oil, I do run an oil cooler and its working well. I run either a 5w40 or 10w-40 weight oil and the temps have consistently been about 210-220 F max even with sustained lapping on a rather hot ambient circuit. It is for this reason that I am wondering if a good 5w-30 like a motul 300v might actually work well without giving up much in terms of wear since my cooling setup seems to keep the oil temps down.
rob-2: I am concerned about the transmission fluid as my previous UOA did show the oils there shearing down quite a bit. I did use Honda MTF previously but it seemed to shear down all too quickly. The known quantity I have was an UOA on Motul Gear 300 75W90 in the transmission and it seemed to do well. I generally change the transmission oils out every 10-15K miles if i get down to the track a bit more often.
#23
Originally Posted by c32b' timestamp='1341368884' post='21832671
iirc, 75W90 does work for our car differential. I did a UOA once and the results were good. Looks like I have had itchy fingers and possibly messed up by fixing something that wasnt broke.
1. I didn't say 75W90 won't work in a diff. In fact, if it's rated a GL-5 fluid, it is more than fine. What I said was you should NOT be using a 75W90 diff fluid in the transmissions of early models of S2000. As for the thickness for use in later S2000s, see point #2 below.
2. I specifically said that the stock tranny fluid is equivalent to a 10W30 engine oil since it can be used in place of Honda MTF when MTF is not readily available. Do you really want to put in a 75W90 viscosity fluid (even if it was NOT a GL-5 fluid) into a mechanical casing that normally runs a much, much thinner fluid? But then, it's your car. It's your choice.
btw, have you had a chance to see how high the diff temps get on the track?
#24
Originally Posted by c32b' timestamp='1341445302' post='21834461
Quick question: what sort of temps would be considered "high" for the oils? Anything above 120 deg C?
Oil running through a crank journal at 9k may reach 150C (HTHS conditions) for a split second.
Oil being sprayed towards the pistons could get hotter I think, but also for a very short time.
That's normal.
I think you want to keep sump oil temps below 120C - engine oil.
As for the diff and trans, I've measured my diff oil right after draining once and found it to be around 70C.
This was after a spirited drive with ambient around 20C (IIRC)
The trans may get a little hotter as there is heat energy from the engine going into it.
IMO if you're not endurance racing diff & trans temps are no issue.
rob-2: the racing oil comment was about the 10W-60 "racing oils", regardless of brand.
Redline is top notch stuff - no doubt.
Their 0W-30 was/is high on my list, especially now the Amsoil SSO is out of production.
IMO, for an occasional track day on street tires, a 30 weight will be fine, I've done that twice, UOA after 15k or so including a track day showed nothing.
On r-comps / semi slicks you need to worrie more about starvation in long sweepers, IMO.
No oil will save you if it is not there.
#25
#26
Here's a link to my oil temp post: https://www.s2ki.com/...1#entry18847621
Maybe the minutes it took to get the car on jackstands is allready enough to lower oil temps?
Or... it was the SAE 190 keeping it all cool
I remember a post on a 4x4 forum I found through BITOG mentioning lower diff tems running good-ole LE-607.
Less friction = less temp.
Did Spoon ever pay anything?
Ha
Its YOUR thread, you can do whatever you want inhere
IMO, yes, your oil temps are very good and no reason to go 40 weight.
You may actually see even lower oil temps with a 30 weight as more oil will flow through the engine - AND heat exchanger - at higher revs.
Redline will have a nice shear stable / good HTHS oil for you no doubt.
#27
#28
SpitfireS: reading your thread, I realised I need to update that my final drive is now 4.44 (GT Motoring). Not sure how much of a difference this makes from me using the oils I do.
rob-2: current OCI for diff/trans is about 8-15K miles depending on how frequent I track. Your sharing has led me to get this oil out of my gearbox asap which I will be doing in a few days. I'm really grateful to the community for their open advice.
#29
People can sometimes go nuts when dealing with fluids for their cars. We live in a paranoid and anal retentive world.
Back in the early days of the S2000, it was well documented that "dino" oil of the recommended viscosity analyzed very well. Even after 7500 miles of different kinds of driving conditions, the analysis showed that there was still plenty of life left in that oil. And now, we see owners of S2000s who obsess over what kinds of oils they "must" use in their cars. "Gotta have the best. Money is no object." And still, they blow their cars up. It's not the oils they use. It's the way they use (or abuse) their cars. It's the lack of knowledge and understanding of how the car works that ultimately destroys them. They ask the questions but they don't believe the answers nor do they understand some of the answers.
#30
In any case, I take the opinions combined with data points like UOA to make a decision and frankly am very grateful at the generosity of the community with regards to info sharing. I'll be the first to admit that I don't know much (if at all!) about the dynamics of oils but it's nice to know people are willing so water it down to I can at least understand the gist of it.
