6th gear swap
6th gear swap
I will be putting my 4.44 gears probably tomorrow, and I was wondering the following:
Will an RSX-S (or any other Honda with a lower ratio) 6th gear be interchangable with the one found in the S?
If its posible, then this would greatly help with cruising revs when doing a diff mod.
Originally Posted by Slows2k,May 27 2005, 12:38 AM
I highly doubt it, as the S's Trans is unique to te entire AHM model line.
5th and 6th gears are Overdriven.
5th is .971 6th is .811 on a 00-03 car
5th is .943 6th is .765 on a 04-05 car
Chech out this gear calculator: http://reverendsgarage.net/index.php?conte..._calculator.php
I have the 4.57's and I get 25-26mpg normal, and 31mpg on long trips.....
my normal gas mileage went UP (from 21-23mpg), and my freeway mileage dropped about 2mpg. i don't think it's worth the hassle in any way, shape or form. IMO
I wouldn't worry about it. at 75 mph you're still only around 4300 rpm in the '04. you could cruise on the highway for hours on end at 5000 rpm and still be fine.
I'm most likely doing 4.56 myself down the road
Originally Posted by s2kVABeachCruiser,May 27 2005, 08:24 AM
Can't you just put the sixth gear in from an '04 or '05 transmission?
Crusing at 2.7-3k for 65mph, not only will it help in milage, but also in engine longetivity.
