60mph at 4000 rpm in 6th gear?
i just realized my car is at 4k rpm in 6th gear going only 60 mph.
and my other s2000 when im at 4k rpm im at around 70 mph.
s2k #1 has headers straight pipe greddy exhaust, f22 engine with ap1 tranny and 02 ecu
s2k # 2 ap1 engine and tranny 2001 ecu, all stock.
does this mean there is something wrong with s2k #1?
the previous owner said he never did anything to the ecu or gearing or anything.
different sized wheels wouldnt make a difference that big.
Gear calculator is showing 6th gear at 4k RPMs with stock gearing is 75mph and with 4.77 final drive is 65mph, which is right because thats what I have.
Can you hit 60mph in second gear?
http://www.youtube.com/watch?v=QH6ZVWcSOFg
i did it this morning.. doesnt seem to be that clear. let me know if its ok
Something is obviously different between the 2 cars. Bigger rims alone will not change the speedo reading. It would show the same speed at the same rpm, but you'd actually be going faster than that. Same applies to a changed final drive gear. Something like a yellow box can be put in to adjust the speedo for the different rims. So possibly one of the cars HAD bigger rims and a yellow box, and the latter was not removed.
Car #1 f22(AP2 engine) engine with (AP1) tranny, won't that make the rpm's higher?
As for the speed-o. Dose it take 60 sec. to go one mile? If it does then your speed-o is right on at 60 mph.
ROD
ROD
One mile as measured by what?
hes trying to say go to 60mph and then reset the trip and time a min. if you go a mile in a min then your gearing should be correct with the speedo
