5th Differential, probably need a 6th
Originally Posted by elemental79,Oct 10 2007, 02:15 PM
Yeah, all the diffs with the problems I've mentioned, I have taken apart and can not see any signs of damage. Nor can I hear anything turning by hand. It just seems logical that it must be the prop shaft. But if so, why did changing the differential fix the noise for a whole year? A year of rough track time. I'll be replacing the prop shaft tomorrow (when the part gets here). My suspicions are it may fix it, but the damage may already have been done to the differential (if it has anything to do with the diff that is).
Modifry, was the boot on that "Bummer" CV joint damaged? Where did the grease go?
I just got done taking off the prop shaft, wiggling it arround and putting it back on. (aligned it to the opposite side of the bolt patern). And it stopped making all noises. I havent had a chance to take it over 70. But I'm sure it would break again. So now im 99.9% sure its the prop shaft and the last 3 diffs that i have purchaced are probably fine.
At least you've got a couple perfectly good differentials that you can sell to get some of your money back.
i had the exact same problem i went through 4 diff's and locked up one going 40 mph i finally sold the car and i later found out the propeller shaft was unballanced and it caused a snow ball effect from there, so have that checked!
