45k miles unknown previous oil can i go fully syn
Old 12-16-2006, 01:18 PM
negcamber's Avatar
Originally Posted by SpitfireS,Dec 16 2006, 02:48 PM
IMO modern API SH-SJ-SL dino oils don't leave / create a lot of sludge / varnish that "hide" seals that may leak.
Could very well be true...I'm not really sure how much technology has changed for normal dino oils over the last 20 years. I assumed that oil companies would have put most of their R&D towards the synthetics and blends. Those have certainly been the oils heavily advertised other than the newer oils for high milage cars (which I would think are actually designed to "hide" leaks).
I can tell you my experience and the "conventional wisdom" says higher milage cars that have exclusively used natural oils have more sludge than ones that have primarily used synthetic, and switching to synthetic after that sludge has built up can lead to leaks.
Dunno...your experience may be different...I can just tell you what I've seen.
Old 12-16-2006, 01:42 PM
RACER's Avatar
Like spitfire said, if an engine is leaking oil, it should be addressed no matter what type of motor oil is used.
Conventional motor oil may help restore compression on a high milage engine, as in aid the piston rings.
I used Mobil 1 5w-30 on a MY94 Del Sol VTEC that had 54k when I got it. The previous owner (1st owner) used conventional oil. I switched to Synthetic Motor oil right away. That car saw 8,200 rpm's every day during my ownership. That thing was fast for a 1.6 liter n/a machine.
When I sold it at 135k miles, it ran like a thoroughbred race horse
Old 12-16-2006, 01:44 PM
RACER's Avatar
And it didn't burn any oil.
Matt_in_VA
07-19-2004 04:38 PM
VR WHAT
06-12-2003 07:20 PM
SoDakS2K
03-26-2003 09:47 AM
UCrazyKid
10-14-2001 02:18 PM
Whooopasss
07-12-2001 07:49 AM
Quick Reply: 45k miles unknown previous oil can i go fully syn
