4-Hole Oil Jet Bolts Found on Engine #5072 MY2002 !
#21
The bracket looks attached to the pan.
#22
Originally Posted by JFUSION' timestamp='1341358256' post='21832297
I just remove the two lower bolts of the a/c compressor bracket and leave the upper ones installed, it is enough to allow the pan to drop without touching the compressor itself. You just need to have a proper tool to access the lower two bolts.
#23
interesting.... My block number is 1025223, built in April 2002. I always thought i missed out on the upgraded bolts, but now I have new hope! I'll have to check this out and let everyone know.
#24
I'd actually be surprised if there was a single clean cutoff point, where every engine below that # has the 2-hole bolts, and every one above it has 4-hole bolts. For the purposes of the TSB, Honda will have simply identified a point where they're sure that no "straggler" 2-hole motors were left.
Until you actually check, you'd be wise to assume that if you're under Honda's official cutoff, you have the 2-hole bolts.
#26
Originally Posted by iDomN8U' timestamp='1341503686' post='21835767
[quote name='hybridb18' timestamp='1341423691' post='21833845']
[/quote]
Unfortunately Honda has no "official" cutoff point, the last number of xxxx5376 was simply the last reported engine where the owner found 4-hole bolts (prior to me finding mine). In North America Honda was completely "mum" on the subject and wouldn't even confirm that the issue of 4 hole vs. 2 hole bolts even existed. This is my biggest complaint of Honda with respect to the S2000, they just wouldn't discuss the issue in North America.
#27
Jfusion...
I actually got Honda to warranty an engine for a guy based on the oil jets. He had a genuine number 4 cylinder failure. I got the official recal letter from a guy abroad, it was in dutch, and I had it translated.
The car was topped out on a long road at 154mph for 90 seconds or so. Think about that. This is hard to do in the USA, unless you live in the desert.
I told Honda I would prove this and I also told them I would not tell anyone about our arrangement. Well its been many years so the dust has settled. They hated me at first but now would love to have me work for them I am on great terms with them today.
#28
Jfusion...
#29
I think it was earlier than August. By then 2003s weren't far from hitting dealerships. My '02 was built in June 2002, I took delivery in July, and it has the 4-hole jet bolts (based on the engine #, I have not verified this visually).
#30
Originally Posted by JFUSION' timestamp='1323629468' post='21228140
It was also noted that the changeover on the factory line happened in August 2002, but my car has a build date of April 2002.
