4.77 installed... what rpms @ 70mph
Old 07-23-2005, 04:51 PM
AllStock27's Avatar
Default 4.77 installed... what rpms @ 70mph
Ok, i'm a lil paranoid n i just want to make sure, n the search function is not working right now... the 4.77 gears were recently installed in my car, but haven't purchased the "speedometer corrector" lol - to correct the readings off the dash.. but right now, @ 70mph, its 3900 rpms... does that sound about right if i haven't installed the "yellow box" ( or i think thats what they call it...) I just want to make sure i didnt get "jipped" by the shop. Thanks for any input.
Old 07-23-2005, 04:54 PM
Ro_Ja Boy's Avatar
Install the yellow box!!!
Old 07-23-2005, 05:16 PM
xviper's Avatar
This is too late for you but it may be of help to others in future. You should have counted the teeth on each of the ring and pinion gear. Then divide it out and you'd know the answer without any doubt.
Without the Yellow Box, your speedometer and tach will read EXACTLY what it read before, except for the fact that when it says 70 mph, you are NOT going 70 mph. The tach will still read the same at 70 mph now as it did before since nothing has been corrected. You need to get paced by another S2000 or police car at 70 mph to see what your tach says. Then you have a point of comparison.
Old 07-23-2005, 05:59 PM
Wisconsin S2k's Avatar
also, keep in mind that while you don't have this fixed, your odometer will be adding on incorrect mileage.
Old 07-23-2005, 06:43 PM
steven975's Avatar
your true speed is 16.34% higher than indicated.
you do the math.
Old 07-23-2005, 08:26 PM
xviper's Avatar
you do the math.
Actually, the "true" road speed would be 16.43% lower. The speedo would read higher than what the car is really going.
Old 07-23-2005, 10:32 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
On my stock s2k when it was stock:
At 4000 rpm's, I was doing 72.5 mph.
Old 07-24-2005, 07:16 AM
xviper's Avatar
That's pretty close considering that there's 1% to 2% difference from one S2000 to another.
Old 07-24-2005, 01:59 PM
DrCloud's Avatar
Originally Posted by xviper
Without the Yellow Box, your speedometer and tach will read EXACTLY what it read before...
Um, I thought I understood this stuff, but now I'm confused. First, this statement is correct -- it's just that the speed will be wrong. A GPS is useful to get a correction, in addition to the pacing. But your mention of the tach is what mixed me up.
These gears will, of course, affect the final drive ratio and therefore the speed; this is why you need the Yellow Box to correct the speedometer (just as you do if you change the tire size).
But the tach is the engine RPM, right? It really doesn't have anything to do with the gears or the Yellow Box correction. (And maybe this is what you're saying, but I want to un-confuse myself.) TIA. HPH
Old 07-24-2005, 02:02 PM
what he's saying is that the rpms are reading correctly. as they should. but while the rpms and mph are both giving readings (the same reading as before) the mph is actually incorrect. so to come on here and say "my rpms are 3900 at 70mph" doesn't tell us anything.
Scenario A: if he was stock his car would show 3900rpm at 70mph.
Scenario B: if he had 4.77 gears and NO yellow box, it would still show 3900rpm at 70mph.
the ONLY difference from the first scenario to the second is that he would not actually be going 70mph in Scenario B.
Quick Reply: 4.77 installed... what rpms @ 70mph
