300,000 miles AP2 - fix or engine swap?
Old 06-09-2021, 10:31 AM
Jah2000's Avatar
It's fine. It'll prolly go another 300k miles, and then another 300k miles, with regular maintenance.
Old 06-09-2021, 10:49 AM
ISADE's Avatar
If you are worried about the bottom end then you should have already been getting your oil tested after oil changes. I use blackstone laboratories because it's fairly nearby, but they send you containers and you ship them back an oil sample. This tells you a lot of stuff, are you getting coolant into your oil, are you getting fuel into your oil, are you getting rod or main bearing journal material in the oil etc etc. If this comes back good don't worry about the bottom and just redo the top AFTER you confirm it's the top end with a leakdown test.
Old 06-09-2021, 08:09 PM
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Assuming leakdown confirms its top end, once head is removed you can inspect tbe bores. If no serious scoring or out of round, you're good.
Its the cylinder walls that make these engines not rebuildable. Pistons, rings, bearings can all be replaced and be reliable, so long as correct size bearing color codes are used. Cranks are expensive and hard to find good ones. So long as you don't loose a bearing (likemrod.knock, etc) your crank will probably be fine.
So if head comes off and you find heavy cylinder scoring, then yeah, maybe rebuilding head isn't worth it, as block doesn't have a long healthy life ahead of it. But so long as cylinder walls still decent, go for it.
The following 3 users liked this post by Car Analogy:
ISADE (06-10-2021), rpg51 (06-10-2021), Slowcrash_101 (06-10-2021)
jpark
Member S2000 Classifieds and For Sale
09-02-2018 06:51 PM
LeonV
23
01-01-2017 03:51 PM
Black Betty
09-14-2010 05:42 PM
yelis300
Florida For Sale
05-30-2010 09:22 PM
yelis300
01-20-2010 09:28 PM
Quick Reply: 300,000 miles AP2 - fix or engine swap?
