2ndary air pump
I was wondering if anyone knew the flow rate of the secondary air pump. I tried the search function to be no help. I just wanted to know how CFM the air pump flows. I also was unable to find it in my honda service manual.
Any help would be greatly appreciated thanks!
Secondairy air pump?
Do "we" have 2 air pumps, as in a primairy & secondairy?
Or is the engine the primairy air pump?
Can't help you with the CFM question.
Sorry.
Why do you want to know?
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
Sorry.
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
I can't help with the flow specifications on the pump either. But I believe it's called a secondary air pump because it injects air into the exhaust manifold. Any unburned hydrocarbons then get enough oxygen to burn off in the manifold. So the manifold becomes a "secondary" combustion chamber. So yes, the engine is the primary air pump.
Its the little air pump under the front bumper on the driver side.
You would probably all laugh if i told you what i was using it for, but long story short.
I have a mini-bike project and a 5.5HP motor and wanted to see if the flow of the air pump would over come the flow of the carb on the motor to essentially make an electric supercharger.
I ordered one from a fellow member for 30 bucks. I am going to attempt to repair the housing and use it for this project.
I figured I might have a chance with the air pump having a higher flow than my motor considering its intended application. I know its wierd but hey it was a free mini-bike and a 30 dollar fan lol
