2nd gear grind?
2nd gear grind?
What's the best advice for solving the gear grind from shifting from 1st to 2nd (MY 00)? I know i'm fully depressing the clutch while shifting, yet if i shift from 1-2nd gear at 4,000rpm or higher i get gear grind. I don't have any other grinds other than 1-2 and it really sucks not being able to take 1st into vtec and shift cleanly.
My warranty has expired and i'm curious if Honda will do this TSB fix https://www.s2ki.com/stor/library/TSB/A00-055/index.htm out of "good will" as they stated.
Please don't post on how to hold/use/grip the short shifter...I have tried A LOT of different grips on the shifter and it's the same outcome. The only way i'm able to shift 1-2 at 7000-8000rpm is by SLOWLY depressing clutch and shifting -- so much delay that i usually bog into 2nd gear
p.s. Does anyone know how much this TSB repair usually costs if not covered by Honda?
Thanks in advance
Thanks in advance
S2oooNvegas - I know you are only trying to help. But
What NOT to Post Here #4
Clearly says not to advertise parts or services.
I hope you can understand.
flush your clutch fluid if you haven't done that in a while.. if that doesn't work, adjust your clutch pedal.. (well, not the clutch pedal, but adjust how deep the shaft goes into the cylinder..) do a search and you'll know what i'm talkin about.. Adjusting the shaft on mine (shaft went inward just a tad) improved the shift.. )
