2nd gear grind
Administrator
Originally posted by S2kenvy
doh, didn't realize you can't edit posts but I meant to add I thought the 02 models had tranny changes that were suppossed to smooth out these issues. Also is the synchro issue with all years? I have a specv, horrible shifting/grinding from factory, replaced with synchromesh a while ago and its been but not great. I read before on here that synchromesh isn't good for s2ks but redline is.
I agree with Xviper and Ludedude.
I've suffered a severe 2nd gear grind that resulted in my original transmission being rebuilt and then ultimately replaced altogether.
I've experienced a much milder 1-2 upshift grind in the new transmission (4000 miles on it with only two mild to slightly moderate grinds). The transmission was extremely notchy with the Honda MTF so I switched to Redline and it has solved most of the problems. As Xviper mentioned, it seems to do it mainly when the transmission is hot. Additionally, as Xviper suggested, I also changed the fluid in the clutch master cylinder (completely bled it) and that seemed to improve the clutch pedal response. The 1-2 shift takes some time to get right and requires a little more discipline and good technique.
