23 mm 3/8" drive 6 point socket, anyone know where I can purchase one?
Topic basically says it all. Trying to loosen the fill bolt on the differential, but I can't get it off. Was stripping it with a combination wrench. Would need a 23mm 3/8" drive 6 point socket to put on there to get it off, but I can't find anyone that sells one. Went to Sears and Harbor Freight and neither one had one. A 1/2" drive one is too long to fit in the space because the 1/2" socket wrench is thicker. So anyone know where I can get the socket?
ok after some more searching, I found that snap on carries one.
http://buy1.snapon.com/catalog/pro_det.asp...ore&dir=catalog
I can't use a combo wrench guys, my 12 point 23mm combo wrench stripped corners on the fill bolt on my differential, so I'll either need a 23mm 6 point socket to get it off, or drop the differential and put in a vice to get the fill bolt off.
