2006 clutch master cylinder install issue
Old 11-06-2017, 09:19 PM
simbabear's Avatar
Default 2006 clutch master cylinder install issue
Hit a brick wall while replacing my CMC. Due to the fuse box being an inch away from the CMC, I'm having a heck of a time connecting the clutch line and threading the nut back on. It's either the nut dosent thread on right and feels like I'm going to cross thread it. I've asked help on FB, and someone mentioned that removing the fuse box will help, but not sure how to completely remove it. Any trick or tips will be appreciated.
Old 11-07-2017, 02:34 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Fuse box lifts out, two release tabs.
Make sure the MC mounting bolts are loose, this helps the MC to shift around and better align with the line.
Old 11-07-2017, 03:47 AM
DC5Daniel's Avatar
I️ wasted two hours having the same problem as you. Once I️ finally gave in and moved the fuse box, I️ was able to thread the line in within seconds. Not sure if this is an 06+ issue, but for anyone in the future, save yourself the hassle and move the fuse box.
Old 11-07-2017, 06:31 AM
maranelloboy05's Avatar
I wasted a ton of time and crossthreaded the line on my last car. Pull the fuse box haha
Old 11-07-2017, 08:33 AM
freq's Avatar
Why are all the CMCs being replaced?
Old 11-07-2017, 11:00 AM
simbabear's Avatar
I loosened the MC and that helped with the creating a bit more space. Silly question, do I need to get into the fuse box to undo the clip?or is the clip located outside the box? I only see one cable going into the fuse box and don't see a clip... I've tried searching for fuse box removal, no avail
release tabs.
Make sure the MC mounting bolts are loose, this helps the MC to shift around and better align with the line.[/QUOTE]
Old 11-07-2017, 11:06 AM
simbabear's Avatar
Logged in a goof 4 hours trying to put this thing on, anyone have any diagram on where to unclip fuse box?
Old 11-07-2017, 04:38 PM
simbabear's Avatar
I'm assuming I'm supposed to remove the two bolts attached to the fuse box, before I do that, will I mess anything up if I do?
Old 11-07-2017, 04:42 PM
Billman250's Avatar
Look to the right of the right blue screw in the pic. You will see one release tab, it’s black plastic. There are two.
Use fingers, no tools needed.
simbabear (11-07-2017)
Old 11-07-2017, 07:39 PM
simbabear's Avatar
Thanks Billman, I think you're talking about this piece of plastic. I tried squeezing it, moving it, pushing on it, but no movement. Tried to move the clip above it and it broke
Quick Reply: 2006 clutch master cylinder install issue
