2004 S2000 Turbo
Originally Posted by honda9krpm,Sep 28 2004, 07:24 PM
looks good
but with all of that money spent I am still surprise to see the bleed valve. You should invest in a electronic boost controller
Tim
Originally Posted by StinkyTofu,Sep 28 2004, 04:46 PM
timq: thanks for the breakdown. Although you took a pricey route, the price includes the aem ems and wide band, so its really not too bad. Basically you paid the same price as a comptech supercharger without aftercooler + aem ems and wideband. I'm really anxious to see the power curve for your set up. Hurrry and get that thing tuned!
Tim
Originally Posted by HvRRZ,Sep 28 2004, 09:40 PM
did you go with the standard gt 4-bolt, or the t3/t4 style 5 bolt? and how about the turbine A/R, .82 or 1.06?
"FULL STEEL BALLBEARING CENTER SECTION
Ported shroud compressor housing, allowing for a more effecient compressor.
compressor specs: GT30 w/ported shroud
.60 a/r
compressor wheel trim: 56 trim wheel
compressor flow: 53 LB/MIN
turbine specs:T3
.63 a/r
84 trim wheel
Water cooled and oil lubricated bearing housing standard.
full steel ball bearing cartridge, not ceramic..."
Tim
Originally Posted by AusS2000,Sep 29 2004, 07:05 AM
I didn't see a price for the turbo manifold unlessit's one of these:
Pipes, welding, install $630.00
Exhaust Manifold $175.00
Tim
