2003 S2k ECU Question
Hi,
I need some help again on wiring the ECU harness that was cut. On one of the harnesses (the one with 32 pins), there are 2 blue wires and 2 red wires. On all the wiring diagrams I have looked at, they are simply denoted as "BLU" and "RED". However, the actual wires have one and two silver rings every inch and a half to differentiate between the two blues wires and the two red wires.
The wires in question are:
Connector A (32 pin):
Terminal 2, RED: SAVS (air control solenoid valve)
Terminal 17, RED: ACC (a/c clutch relay)
Terminal 19, BLU: NEP (engine speed pulse)
Termnal 28, BLU: APR (air pump relay)
If anyone could see which of these wires have one or two silver rings around them on the wire, that would be awesome. Thanks in advance.
-kuni@edesignmedia.com
Looks like a recovered stolen car. If so, man I feel for you.
I checked my wiring diagrams and it is unclear.
Here is the blue T19 located on the connector under passenger side cover.
I recommend a volt meter to test for continuity from these wires to the specific component.
