Is this 2002 S2K the updated banjo bolt? With engine SN
I'm looking at a used S2K 2002. I understand halfway through the year, they updated the banjo bolt.
Though it's not definitive, around engine serial F20C 1102 5386 you'll find the updated bolt.
I'm in Canada...but most used S2k's around here are US imports. This 2002 I'm looking at appears to be a Canadian car so I'm not sure if the Engine s/n's are different.
Engine block says F20C1-1120253
So is this a very early build S2k for 2002? Like #253? All the digits don't match...so I'm not sure how to read it.
Thanks for the advice!
The build date on the sticker in the driver's door jam will give you a major clue. For example my 2006 car was made in July 2006 making it a "late" 2006 -- just missed being a 2007.
Nothing you can do about the banjo bolts either way unless you want to open the engine...
-- Chuck
-- Chuck
