20 psi Turbo Engine Build
I just bought a 2001 vintage short block, and spent the morning dismantling it. The engine came from someone in Ohio. It had a busted #4 connecting rod and cracked oil pan. Number 4 cylinder has one good gash in the bore, but other than that, everything looks good for an engine buildup. I'm planning to have AEBS sleeves installed along with forged pistons and rods. I'll use the stock crank shaft. Other than the obvious such as 4 hole oil bolts, new studs and bearings, what else should I be considering. My goal will be 20 psi of boost, and whatever HP that gives. Any suggestions on brand of rods and pistons? Anything else I should consider? This will be a long term project, but I hope to be done by the end of the year.
Does anyone from Ohio know the history of this engine? There can't be that many 2001 broken engines in Ohio.
Does Darton have a sleeve for the f20c block s2000pr?
I checked last week and they said they need a block to do some R&D otherwise no off the shelf sleeve for this block atm.
Originally posted by beroznikmal
How about the 2.2 toda stroker kit... it comes with the lower compressiomn pistons.....
Beroz
Beroz
Originally posted by fperra
Darton sleeves would be my second choice, but I'm going with the best - AEBS.
$400 a set without installation is what I got quoted from AEBS.
Does this sound right?
