2.4L p0171 and p0170... duh?
Old 11-30-2011, 12:34 PM
  #21
chris_barry's Avatar
Not sure if this link will work but here you go
https://docs.google.com/open?id=0Byx...M4YzQ4ZWNmZDU5
AEM F24c program
all the usual disclaimers apply.
This was for the engine in this thread.
Aussie F24C 2009
Old 11-30-2011, 02:30 PM
  #22
ry4nolson's Avatar
AEM F24c program
Aussie F24C 2009
Very Nice! thank you sir.
Old 11-30-2011, 03:13 PM
  #23
The RC tech 550cc injectors I used with this program are sitting in the workshop surplus to requirements as I upgraded to ID1000's when I moved to E85. They also have plugs with short pigtails on them.
PM me if you are interested in them real cheap.
Old 11-30-2011, 03:18 PM
  #24
EagleDon's Avatar
Ry,
I am impressed with the Mechanical aspects of this build. Putting aside the electronics, I like the idea of combining the H22 and F20C components to achieve the "stroker". Absolutely Awesome build.......
Originally Posted by ry4nolson
So I just had my engine overhauled at 85k after spinning a rod bearing. I opted to do the budget 2.4L stroker using h22 pistons and k24 crank since #1 it's cheaper than building with f20c parts and #2 it was cheaper than buying a used engine (and #3... why the hell not?)
Low and behold I have it all back together now after the engine being at the machine shop for 4 months. After driving for 2 days I just had the CEL come on and it's throwing P0171 and P0170 - fuel system too lean. DUH.
Real question, is there anything relatively inexpensive I can do without a full AEM EMS or Kpro or any standalone ems? These are pretty far outside my current budget (and knowledge comfort zone)
Is it safe (loose definition of safe) to drive the car with this on and without full tuning?
Old 11-30-2011, 03:21 PM
  #25
Banned
vividracing.com's Avatar
So is it unsafe (as in burn up the engine) to run the car with it like this?
Yes, it is unsafe. You need to see what exactly your AFRs are, though. A stand alone is the proper way to do it, but you could use an adjustable FPR and an emanage or VAFC to pull fuel out of any areas that are too rich. PM me if you need pricing on anything. I'd really suggest a stand alone.
Old 11-30-2011, 06:06 PM
  #26
ry4nolson's Avatar
So after a day of normal (and some vtecing) driving the CEL has turned itself off... this is interesting. I wonder if it is adjusting itself.
@vivid. where are you located? I'm within about 2 hours of Houston if i needed to do a dyno tune.
Does the computer base its decision on O2 sensor readings?
My mods are 2.4L stroker, Fujita CAI, PLM header, test pipe, cheapbay exhaust, 4.777 r/e, and probably some other stuff i can't remember.
Old 11-30-2011, 06:37 PM
  #27
ry4nolson's Avatar
Don't forget the key K24 component - the crank.
Originally Posted by EagleDon
Ry,
clarkster009
10-21-2010 09:44 AM
lude9285
09-12-2010 06:27 PM
lude9285
08-26-2010 05:59 AM
skool u
04-11-2010 07:56 AM
TexaS2OOO
06-29-2007 12:28 PM
Quick Reply: 2.4L p0171 and p0170... duh?
