1st oil change!
for the first oil change, when should I do it and what kind of oil should I put in. do I really need synt oil? all I see in the owners manual is to check the maintenance manual that by the way is about 75 bucks.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I'd wait till 5k-7k , and keep with regular oil, not syn. Wait till 10k for the syn.
BUT...do check it at every fuel stop. A new s2k can burn lots of oil when it's new, enough to destroy the engine. And it will not be covered, because the manual tells you to do so
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Can't remember exactly where I saw it but I think it's in the OM and the emphisis seems to be on leaving the original oil in up to the full recommended 7500miles.
Like you, I'm a little anxious and would rather change it a little earlier.
The break-in oil appearently is a special formulation and should remain in the crankcase as long as possible.
I think I'm going to compromise a little though and do the first change between 6500-7000.
Synthetic or non, I haven't decided yet. It probably doesn't make a huge difference one way or the other.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Originally Posted by S2000 Rx Guy,Nov 9 2006, 07:55 PM
My ap2 has 5k miles and 1 oil change,
It's dark and I can't find the dipstick?
Where is it?
Where is it?
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
and yeah, definitley keep an eye on the oil level. i'm almost hitting 2k miles, checked it today, and saw it was near the lower X. i topped it off with some high mileage valvoline oil. do not put in full synthetic until/after 10k. stated many times before, everything within the engine is still being seating/broken in even after 5k miles.
Originally Posted by JiuJeetz,Nov 9 2006, 08:13 PM
Ive been checking the oil level and its good. do you guys think that the oil live % will reach 0% before 7k?
On my MY06, the 15% came on at around 5k. It insisted I change it because every time I toggled it out of the way to get my display back and shut the car off, it came back as soon as I'd start the car.
So my first oil change was at 5k with a K&N filter. I did the second one at 3750 after and the % was at 40. Going to do filter every other time. It seems the % runs ~5k miles, at least on my car. I drive really hard and autox, canyon run regularily. But I'm going to stick to 3750 from now on.
I have not burned any oil at all.
Also, I would change the transmission and diff fluids at 5k as well. They were nasty.
Reset your minder if you change stuff early. I had code 1A first time and 1B second time. Those are listed in your book.
welll i changed mine @ 4200 miles... just felt different every time i started the car.. i drove my car very hard after 1k so i am useing the extreme condition guidlines..actually a bit past it.. i think for extreme its 3750 miles .. o well... my next oil change will be around 7500 + dif +tran..
after that.. its full syn from there..
You might be able to run your oil 5-7k but it is recommended to change you filter around 3k. The cleaner the better IMO.
Remember the three jobs of oil:
Clean
Lubercate
Cool.
Clean
Lubercate
Cool.
