1st gear and reverse gear got stuck....
Old 06-09-2003, 06:14 PM
xviper's Avatar
Do what UtahS2K suggested. What you describe would be more in keeping with a clutch fluid issue if everything was HOT. But since you see that the fluid is black, it certainly wouldn't be a bad idea to change it at this point. It may not solve your problem (if indeed it is a problem) but it's a fairly easy thing to do and it won't hurt.
If you want to try it yourself, look here:
https://www.s2ki.com/forums/showthread.php?...threadid=118878
Old 06-09-2003, 07:51 PM
ecnay's Avatar
hey utah s2k, you are right man... but instead of going to the diamond bar honda, i went to my friends dad, who is a mechanic, and have the trans oil, clutch fluid and engine oil changed at one time. i paid only $15 + i brought my own neccesary fluid of course. its a good deal. and everything is fine now. PERFECT....
thnks guys
Old 06-09-2003, 07:54 PM
ecnay's Avatar
oya, one more thing, my clutch fluid was BLACK... theres even a sticky residue in it. disgusting, but had it changed so its fine, most probably thats the cause.
so swtazn97, you might want to try checking on your clutch fluid!
good luck and thanks guys.
-ecnay
Old 06-09-2003, 08:16 PM
FormerH22a4's Avatar
ah yes, the clutch fluid. I am starting to think some of these tranny problems are actually because of the clutch fluid instead where there isn't enough pressure to release and have drag.
I had a 1st -2nd grind where shifting into 2nd is always a challenge. After changing the clutch fluid, my 1st to 2nd shift is back to being like new again.
My clutch fluid was BLACK, with solid residue and solid particulates. I am guessing the clutch fluid from the factory isn't very durable. I only had my car for 15 months.
Old 06-09-2003, 09:02 PM
xviper's Avatar
Chock up another one to a clutch fluid change. This is getting quite amazing and a bit of a surprise. But lately, there has just been too many "success" stories to label this as a fluke.
Old 09-06-2003, 02:01 PM
geminiS2's Avatar
So its clutch fluid that maybe the problem or tranny fluid??
Old 09-06-2003, 02:09 PM
sebrings2k's Avatar
Originally posted by ecnay
hey, sebrings2k, are u in the transformer team?
hmmm...nope just an avatar i found...i'm in the south park league now~
Old 09-06-2003, 03:59 PM
swtazn97's Avatar
ecnay: Thanks for the heads up. I'll change my clutch fluid too. What's a good fluid?
Old 09-06-2003, 07:37 PM
Squeezer's Avatar
[QUOTE]Originally posted by swtazn97
[B]ecnay:
Old 09-17-2003, 09:18 AM
geminiS2's Avatar
hey my 2002 has 1st gear getting stuck and as the car warms up it fine what was the problem
Quick Reply: 1st gear and reverse gear got stuck....
