1st to 2nd gear pull
i did a pull last night, i went from 1st to 2nd and i had my 2nd gear get stuck a little or crunch but didnt hear a grind. my car has 29k almost 30k did my tranny flush at 27k cause that happen to me before is there any way that i can resolve this. also i fully stepped on the clutch pedal, i did a honda genuine mtf tranny flush at 27k. if you guys can help i thank you alot. also i drive a 06 s2k
It doesn't matter how fast you shift, the synchros in the car can only shift so fast, so unless you do a perfect rev match upshift (slow), you need them to work their magic. Shifting faster than the synchros will just wear them out prematurely, and fast shifting is a good way to make a mistake and do a money shift.
Just slow your shifts a bit and you'll be fine.
lunardeathgod
06-19-2012 03:47 AM
