19mm subframe bolt part number
i will check my car tomorrow, i just forgot which ones are 19 and which are 17.......i know forsure that number 9 are 19mm tho, those are the 2 center bolts that must be removed in order to drop the subframe and let it hang on the other 4.....sorry its just late and im in bed lol
Originally Posted by hooptie157,May 18 2010, 12:45 PM
I thought the 17's were the ones on the middle and the 19's were the 4 on the corners.
Well, first of all, there are no such thing as 17 or 19mm bolts. Metric bolts come in even sizes only once you get beyond an M5. Most bolts are specified by major diameter of the thread, pitch (often omitted if standard pitch), length, and head type. Things like shoulder bolts can get a little trickier.
#8 are M14x107 Flange Heads
#9 are M14x160 Flange Heads
#10 are M14x130 Flange Heads
#8: 90161-SR3-000 BOLT, FLANGE (14X107) No Color 2
#9: 90161-S2A-000 BOLT, FLANGE (14X160) No Color 2
#10: 90162-S2A-000 BOLT, FLANGE (14X130) No Color 2
There are 2 of each.
Key#12 are M12x162 Flange Heads. There ARE 4 of those. Part number is 90164-S2A-000
Majestic Honda does not use the Honda Part numbers but this site does:
http://www.hondapartscheap.com/southbay/js...0&qty0=1&qty2=1
