1200-1500 idle rpm update and revisited
Hey guys a a couple of months ago I made a forum about a sticking throttle/revs not dropping between shifts/high idle.
Here's an update since then. I finally bought a new map sensor and new iac and had it replaced. And a week later I finally got a CEL.
P0122 - tps sensor "a" circuit low voltage.
Possible open or short circuit condition/poor electrical connection/faulty tp sensor
It's there a way to check if the sensor is faulty or is it bad connect/need cleaning/etc before I actually go out and buy a whole new tb. Sorry for the newbie questions. Never done this before.
Update: when I unplugged the tps and replugged it back in, the cel when away. Does this mean anything?
https://www.s2ki.com/s2000/topic/589...sensor-jacked/
I saw this awhile ago while nerding out.
Looks like Honda wants you to buy the whole throttle body, so this may be a cheap way out.
Sorry, someone else will have to chime in on how to test the tps. I would now how to check voltage to the sensor but not sure about doing it while operating the tps.
